Stephen,
Very interesting link you provided. . The issue with Mr. Teschler's article was with mixing up rate of contribution of CO2 with amount of CO2 at a point in time. Getting a "correct" answer via erroneous means often leads to erroneous conclusions, as many an engineer has learned the hard way.
Nevertheless, Mr. Teschler did not get it correct. According to the analysys in the link you provided, the CO2 rise from 280 to 358 ppmv (from 1800 to 1994) is attributed to human origin, making the human proportion of CO2 today over 20%.
Below are the opening paragraph and some salient points
Time and again, some people claim that human activities are only
a minor source of atmospheric carbon dioxide (CO2) which is swamped
by natural sources. Compared to natural sources, our contribution is
small indeed. Yet, the seemingly small human-made or `anthropogenic'
input is enough to disturb the delicate balance. "Anthropogenic CO2
is a biogeochemical perturbation of truly geologic proportions"
[Sundquist] and has caused a steep rise of atmospheric CO2.
From its preindustrial level of about 280 ppmv (parts per million
by volume) around the year 1800, atmospheric carbon dioxide rose to
315 ppmv in 1958 and to about 358 ppmv in 1994 [Battle] [C.Keeling]
[Schimel 94, p 43-44]. All the signs are that the CO2 rise is
human-made:
* Ice cores show that during the past 1000 years until about the year
1800, atmospheric CO2 was fairly stable at levels between 270 and
290 ppmv. The 1994 value of 358 ppmv is higher than any CO2 level
observed over the past 220,000 years. In the Vostok and Byrd ice
cores, CO2 does not exceed 300 ppmv. A more detailed record from
peat suggests a temporary peak of ~315 ppmv about 4,700 years ago,
but this needs further confirmation. [Figge, figure 3] [Schimel 94,
p 44-45] [White]
* The rise of atmospheric CO2 closely parallels the emissions history
from fossil fuels and land use changes [Schimel 94, p 46-47].
* The rise of airborne CO2 falls short of the human-made CO2 emissions.
Taken together, the ocean and the terrestrial vegetation and soils
must currently be a net sink of CO2 rather than a source [Melillo,
p 454] [Schimel 94, p 47, 55] [Schimel 95, p 79] [Siegenthaler].
* Most "new" CO2 comes from the Northern Hemisphere. Measurements
in Antarctica show that Southern Hemisphere CO2 level lags behind
by 1 to 2 years, which reflects the interhemispheric mixing time.
The ppmv-amount of the lag at a given time has increased according
to increasing anthropogenic CO2 emissions. [Schimel 94, p 43]
[Siegenthaler]
* Fossil fuels contain practically no carbon 14 (14C) and less carbon
13 (13C) than air. CO2 coming from fossil fuels should show up in
the trends of 13C and 14C. Indeed, the observed isotopic trends
fit CO2 emissions from fossil fuels. The trends are not compatible
with a dominant CO2 source in the terrestrial biosphere or in the
ocean.
